Cadstat
I installed my fuel gauge sending units with a stock rubber gasket coated with Fuel Lube because I thought I read that's a good way to do it. BIG MISTAKE. Both failed and started leaking 6 months later. The gaskets squeezed out just enough to leak. It may work if you don't tighten the screws too much or maybe skip the Fuel Lube. I pulled the tanks again and I'm prosealing them now. I also read that's a good way to install them but a bugger to remove later. Well, pulling the tanks again is a bummer too. Just an FYI.
