Bill Boyd
Doing my C I, noted that the cabin heat control was frozen. It's an A-730BL0720 from Spruce. Removed the cable after lubrication was unsuccessful, found on autopsy that the jam was in the final few inches nearest to the carb heat box - it's absolutely seized up, and it appears the inner plastic jacket is deformed and the center wire is touching the spiral metal sheath. I'll be replacing this, obviously, but would like to prevent this failure from repeating itself in another 4 years.
What's the proper way to lubricate these cables that have a plastic inner liner? Is there a high-temp model I should consider instead? Another cable of similar construction running through the same area for the emergency air intake on the bottom of the FAB is the same age and operates smoothly. Not sure what made this one fail.
