I bought a G5 Exp. This is going to be stand alone as a backup. I have the magnetometer. GPS is the question, either internal or external.
External GPS
I want to use my GRT Safe-Fly GPS (to provide GPS information to the G5 via the RS232. Will Garmin accept GPS position from non Garmin Product.
GRT GPS outputs available. RS232:
Serial Port Default Pins
Serial Port 1 Out 4800 baud, NMEA0183 19,20
Serial Port 2 Out 9600 baud, NMEA0183 + RAIM 3
Serial Port 3 Out 115200 baud, NMEA0183 + RAIM 1,2
Antenna
Garmin G5 has internal GPS and requires external antenna. I did not get an antenna. I don't want to add more antennas especially a $250 Garmin antenna. Question do these off the shelf $15 GPS with BNC connectors work?
External GPS
Antenna
