I'm new to the electronics stuff. I ran across this in the install instructions for a transponder.
"Bonding impedance between aircraft ground and the unit chassis must be less than 2.5 milliohms."
Is this the resistance to current flow from the chassis to ground and can you measure it by using a multimeter on the ohm setting with one probe on the chassis and the other on the aircraft body where it attaches? Thanks
