New to me is a RV9A with 500 hrs AF and engine, O320 carb.
I’m Replacing the old ECI cylinders with the AD with new millennium cylinders and going with 9:1-1 compression ratio.
I’m running one conventional mag on the bottom plugs. As I have on hand I’m thinking of Auburn SR83P fine wire with this mag.
On the top is the Light Speed Plasma 2+ ignition
I’d like to stick with a fine wire for the auto plugs as well.
So, just wondering what the best Auto fine wire for this set up would be to match up with the aviation SR83P plugs?
Home strip is 3000 asl so density altitude is normally north of 4 to 5000+ ft Asl so the timing will probably stay at 25 deg BTC.
Certainly open to suggestions.
Tim
Tim
