pilot28906
How are most cutting the Safe Air static line/tube to keep the end square with no burrs?
From Stein Air. Must be available elsewhere. Works beautifully....
http://www.steinair.com/storedetail.cfm?productid=203
I don't have the Safe Air kit. But, for cutting 1/4" plastic tubing used for pitot-static lines, I use the Stein Air Plastic Tubing Cutter, Part No. P-510. Look in the Pitot-Static section of their website.
Thanks guys.
Will the metal tube cutter work with the cutting wheel that you rotate around the tube then tighten with a screw?
I used a Sears Handi-cut tool. Basically just a fancy way to hold a single edge razor against a flat surface.
