Information on Beringer brake pad replacement is not clear. Is there a way to determine what the wear is on a given pad without taking the wheel off and looking at the pad directly (and removing the wheel pants too)? Is the amount of pad visible on its edge with the wheel in place consistent with the amount of pad remaining, or must one remove the pad and look at it? Waiting for signs of too much wear seems foolish and inefficient. Taking the wheels off and removing the pads to estimate wear every 100 hours is PITA. I thought Beringer had a better mechanism to get at the pads without taking the wheels off. I also thought Beringer had significant advantages over MatCo or Cleveland. Seems not. The big difference is price. A replacement pair of Beringer pads cost $334. A replacement pair of pads riveted by Matco is only $75. Do Beringer pads last 5 times longer? Doubt it. I used dual pad Matcos on my RV-7A for 12 years with good results with pad replacement about once a year. So far I do not see much difference in the Beringer single pads for my RV-14A. Yes, the wheels are bigger and have sealed bearings, and the tires are tubeless. But the issue of pad replacement is still convoluted. I now have 110 hours on my 14 and want to know how much wear is on the pads. Seems there is no alternative to removing the wheel pants, taking the wheels off, taking the calipers apart and looking at the pads directly. Am I missing something?
