I’ve reached the point in my tailwheel build where I am fitting the brake system inside the fuselage. After much research I’ve chosen to go with the full Beringer kit.
The Beringer manual shows the ALIR anti skid regulator should be mounted on the rudder pedal centre brace. In my set up I can’t mount it there because the bracket they supplied causes the regulator to interfere with the firewall recess.
So I made a bracket to mount the regulator on the left rudder block instead…
![IMG_9708.jpg IMG_9708.jpg](https://vansairforce.net/data/attachments/25/25577-a9f52c4a832de222862f22dcb4c5604d.jpg)
I like this position because it also means the hoses don’t double back on themselves from the left pedals back to the centre brace then back to the parking brake.
However, this does mean I can’t put the parking brake on the left pedal block as per the original Beringer layout.
So instead I’m thinking of mounting the parking brake on the firewall like this http://www.go-7.co.uk/const/Matco/index.htm
I’ve Googled and searched all over VAF but I can’t find anyone that’s had this issue.
Has anyone else installed the full Beringer system? Have you also had this issue? Do you have any pictures of your regulator and parking brake install?
Thanks all.
Thanks all.
