ScotchbriteThe wheel on my bench grinder that I use to debur the edges of my aluminum ribs, formers, sheets is wearing out. I can’t think of the name of that wheel nor grit to search for. I suspect Vans sells them. Any thoughts how to search for another wheel?
AS has them...Scotchbrite wheel. Around $135.00The wheel on my bench grinder that I use to debur the edges of my aluminum ribs, formers, sheets is wearing out. I can’t think of the name of that wheel nor grit to search for. I suspect Vans sells them. Any thoughts how to search for another wheel?
TyScotchbrite
ty, BobHAAS makes a similar wheel that is half the price of the 3m wheel. Check cleaveland tools website.
NOTE : one of the wheels available is aluminum oxide. The other is SILICON CARBIDE. You can research using silicon carbide on aircraft aluminum and you will find some are concerned that the dissimilar metal particles can cause corrosion in the aluminum. I opted for aluminum oxide after reading about it.Scotchbrite "parts launcher" ... I still like my Scotchbrite 2/3" disks on a 90 degree die grinder.
You can also directly order from HAAS. So you can get almost three wheels for the price for one on the cleaveland page.HAAS makes a similar wheel that is half the price of the 3m wheel. Check cleaveland tools website.
