AirplaneDetective
Member
Rv14 G3x garmin system.
Hey everyone, I’m mocking up the guts of my G3x system and wanted some advice before I start putting holes in things. I’m posting a few pictures, first is how I mounted my gtx45r. The only thing I can see here is that if I put a copilot side mfd, I may have to pull that mfd to slide the 45r in and out. I suppose I’m okay with that as I like this mounting position for the 45r. It’s out of the way.
The second set of pics I’m posting is a some angle I am mocking up to mount a vpx pro and a tcw ibbs . I plan on putting nut plates some all points are removable including the angles themselves. My only question really is do I have enough room on either side of the vpx pro?
Is it a bad idea to put the tcw ibbs there? Should I put the GEA24 instead? What do you think?
Important to mention I did the avionics access panel mod already for the 14.
