Battery Cable Firewall Pass Through?
I am looking at the best way to pass through the 1/4” battery cable.
I am looking at this: https://www.aircraftspruce.com/catalog/appages/eyeballfw3.php?clickkey=147226
Ideas? Better choices?
Aluminum melts at 1100F.
A tubular steel fitting pumped full of a good sealant is gas tight at 2000F. Hot test here: https://vansairforce.net/community/showpost.php?p=549839&postcount=42
Although less effective, the same tubular fitting can be used with a clamped firesleeve cover for wiring and other items where the passage may be accessed later.
This type of tubular fitting is now standard in the RV-14 kits. Center photo, battery, main bus, and control cables on my RV-8
agree with Dan that aluminum is not a good fit here. Steel Tubular flanges are easy to make or acquire. If there is any interest in stainless steel eyeball pass through's like the style in the link, I can make some for purchase. Never seen any in materials other than Al.
Larry
Bathroom
Stainless steel bathroom flange from amazon, filled with flame retardant. QED
In picture it is by the sensor; no fire resistant fill or fire sleeve yet.
Perhaps I pasted the wrong link. I used these for my project and they are definitely steel: https://www.aircraftspruce.com/catalog/appages/eyeballfw2.php
Fiddliness I will leave up others to determine. The steel tube fitting method is good too, just pointing out that if it's a stainless eyeball fitting you want, they are indeed available.
I used the same - they are good, and they are steel. I had bought the aluminum ball with the single nut, before I understood the risks that Dan's been highlighting, and thankfully they were so crappy, I changed to the steel balls. I recommend avoiding the aluminum balls.
If
If you decide to use the SS firewall pass though, I have an Avery kit that I would make you a deal on. I didn’t end up needing it for my -10…
