I have a 912iS Sport installed in a RV-12iS (16 hrs TT) with a Garmin G3X MFD. Starting about 2 hrs ago, the MFD shows the Batt Amps flashing -1. That value will go lower (-2, -3) when I turn on strobes, landing lights, etc. When I turn them off, the amps rise back up to 0 and the flashing stops, but after several seconds it will drop again to -1. The voltage remains at 14.0 or drops to 13.9 when the flap motor runs, but then goes back to 14.0. Alt Amps varies between 5 and about 12, depending on how much equipment is turned on. This behavior doesn't seem to depend on engine rpm -- it will continue in flight (ca. 5000 rpm) as well as during ground running (2500 rpm).
What might cause this? My knowledge of aircraft charging/electrical systems stops in about 1967. To me this seems like a faulty voltage regulator. What diagnostic tests might identify the problem?
