Zero4Zulu
I'm preparing to re-wire my RV6A. Previously the landing light and taxi light were wired to one switch ON-OFF-ON so only one light could be on at a time. Any reason I should keep this or can I have two separate switches so I could have both on? Both halogen lights look identical. Is the aim (elevation) of the lights the only difference between a Landing and Taxi light?
Strobe power supplies are mounted at the end of the wings. Is a local ground at each power supply sufficient? Aeroflash drawing doesn't indicate this clearly.
Same question for the electric fuel pump. Local ground ok?
