For some time now I have had a banging noise while warming up the engine.
The noise appears after maybe five minutes running at 2500 rpm. At lower and higher rpm the noise goes away, and I have never heard it in the air, or while taxying post-flight.
At first I thought it was the exhaust banging against the lower cowl. I checked the exhaust springs. All were intact, but on a couple the safety wire I had threaded through the spring had broken. I repaired this and the noise persisted. I also enlarged the exhaust outlet hole in the lower cowl because there was possibly some evidence of contact. No joy, so far.
At the annual (which I am doing) I checked the four engine mount bolts, because I suspected that might be a possible cause. All the bolts are secure. So now I am running out of ideas.
As an aside, I also found a small (half-inch) crack in the lower starboard firewall, adjacent to the lower cowl mounting point.
Cheers...Keith
Cheers...Keith
