HeliCooper
So I managed to do this...
and I am needing some advice on a good technique to get it out. I have no idea where the center is as I mushed it with the squeezer pretty good.
Additionally I had two ribs push out.
This one I already drilled out the rivet. You can see the flange is pushing away from the rear spar. I could use a good technique to sit these flat on the rear spar. If I get a clamp in I don't have enough room for a bucking bar or squeezer head. This is a countersunk rivet so it has to be put in this way.
Here is the other rib that got pushed out. I couldn't get access to squeeze or buck these so the shop head would be on the spar.
Thanks as always for the help
![vo1JJEql.jpg](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fvo1JJEql.jpg&hash=1abc52b7e2b3cb453baffe8a5ee0463b)
![MOz0pvAl.jpg](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FMOz0pvAl.jpg&hash=fd0e09eb072f8d442e2894cf492441e9)
![urx1L1Tl.jpg](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Furx1L1Tl.jpg&hash=a27d6ad26356061eae23dfd1c397a872)
![93uPZZAl.jpg](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F93uPZZAl.jpg&hash=5074aa5c006fb8925cb5993e9582f14b)
