Autopilot Q.
az_gila
Can anyone share pictures for their connector hookup for the RV-10 Dynon Roll Servo?
I'm using a D-sub connector but can make changes if needed.
You need an extra connection for the power as the lines in the standard D-Sub connection aren't sufficient to run the servo. I used a simple spade connector and local earth.
autopilot servo
Since you don?t use all of the pins because there are fewer than 9 wires I used 2 open pins for power. It made the connection at the servo nice and clean.
I've got that covered since I make the Alexander Network Hub...:)
What I'm looking for is how the connectors are hooked up.
Not sure what pictures you'd like. I used a 9 pin d-sub:
Syo-cucJd0Or4hGLjOuJ23TnItYs1epK3bFPg1zdY5VuORpx_klz5E5Q5tZ-WdRmkeRVMUQ2QVtiT0VYHOpnNKwYnTTDFCMMFJw3_76EwjzUcjjIjI355ILkVtuu6APoHcXRhfynpxmcnB0n_Wld2i5bmxaI83CBDGiSE7YYOEINmPf9epAPPEoqSdhKlV2NGvROPMQUmJrboz3mNhAqlpUIGmI_LwPNGZo13Dks2ZKNFO_XNQ80Cm0qXn6TigEaovmHt3y_92ztMyDws2NmavlETeRBcgblcgLevZ_aQFq2cJaW4gUXLAiKcs0eKKeOcBS0lr3MYDG8WfQnj820F-JUeX-2mS93S8lixshnEl2k6FteKqmzmMvg19KZDQnU7EIhrRY5IjKVPF9eZmv5PuZK_doFBwDOzrAPzGLzyCczx6zwwHHLrMVnZIAhNHmBZG5N6KxX7_l77cYzyfmHwsMgZzQV1sHVDNr9Q_JeHoQpwPWrxbAp1-Y26t-0x4vO1By7er9Nts7YAf5eK4F1uF29h8MzSh81anpnldbDAMPHDiKCXL2kaufii1Egn6Oq3OKrEPSKSsS10m0Aw61iR6M7FaqDWBGdfkcKhTj4HwhKhz5-sXXiGfRV3PmiEyAInViwckk_9O9mT6JVsWxCXB_7hgrlvuFx4qGomL5IeFiafYkhJoTUBi4OLe3BJOmrZPPwxTznhg0bBoynuhxzg0V67c6pztY4Xpjakki7QxabzALO=w1179-h664-no
20Eg8wWIhJ7xLj0TX9v5zATHKOoWR_ghG4UF5g9eZ7ewVmnMj1RA-oKoD5NoTtWyiGCHS4UrskjodLpvwL9L7Y1jqdlEFGPhf7JQIZ-ZOBeSoANTBFdEf5qltFWvKXGf1N5BSQ4Mxdi5m2tDQj08F6wL5NLPNJKOhEIRPdAa5srOFsM9vE93zUkudqk5Bo1jNU6gt2FEkmI_LuCUAiQvE7SKM87ccAPigN_kfHLD13IKv7PHWN8i6fKm4lCMzeIGttERoxoL8G6yEzuXF7JeMKR-50qdCRZRhVTmTCu21cpiinFXFjFY4ES3KWYXhlLL2gbjqXJsir9M3Yk-M09xDzI0zrC9YlkcPso7jpSxEKDnGzyEVmAyfAEFhZ10G7wqB0MfdaqSnRmvj4dTxIQUO3O4fTAn1--2BA6x0sOc4JFTg5mbcifU7k7NJrgCr2Qs1V8Vp8LCCIpvFYDfzBl3PB-qF9rY0X3pTBbFTHRR2kkv3Wi5oF-1O7EK1x04_OpNQNiygPb4bUZ5JqNBCIEUIs-eMG18Lmqvd_Mni3xPfQg-RIjuHUGGj2b_WCmFu5wimoVF79_kzjG1_oes2u-UOUuzla4nnQvemgCme-PT5ODk_BFmUDakI2xtN3kXrC1SFgQxFD71vdEQp5qOO_kad4ribLV4SDsZJI5ASGgXGK8PW1Ffoph6bvLM5BDCqdOSwHTlO5ykLR6iuMXYFGLW9dLGu6CNJ7p0zt-GQWvwGCZ4NWuO=w1179-h664-no
Let me know if the two pictures above don't show up, or if you want some more.
Lynn
