Started the autopilot config per the G3X manual. At the point of turning on the AP and adjusting the heading to confirm stick movement. As soon as the AP is engaged the pitch servo goes to a full nose up position (stick comes full back).
Stein built the panel
Software is most current
G3X
GMC507
On configuration page all servos are “green check”
Tried switching the servo - same problem
Reversing the servo in setting caused just the opposite...stick goes full forward
Trim test works on the trim motors
What next?
G3X
GMC507
What next?
