Here is a recent thread discussing the 386 plugs. Interesting. https://www.vansairforce.net/threads/pmag-spark-plug-guide.176556/Just checking with the group on any Pireps or experiences with these plugs instead of the NGK BR8ES. I run dual Mags on my O-320 with the NGK's but very curious about the autolite plugs.
Thanks!!
Howdy Rico,
I've heard reports that they aren't the correct heat range. I've been happily using the BR8ES 3961 for years. They're cheap and I'm cheerful. If you already have the 14mm adapters, stick with 'em. Haven't seen you around Whiteman lately.
Ed
Rico,Just checking with the group on any Pireps or experiences with these plugs instead of the NGK BR8ES. I run dual Mags on my O-320 with the NGK's but very curious about the Autolite plugs.
Thanks!!
I have run other non resistor plugs, even with resistor caps, and got all sorts of noise on the intercom and immediately removed them. I know the l14u’s are listed as non resistor plugs, but I think they have resistors in them, though may not be the typical 5k ohms. One of these days i will put a meter on them. I have run them in my 320 with ei for 1000 hours and zero issues.I know this is a 386 thread (which is a resistor plug), there has been discussion of non resistor plug use here. Be VERY cautious about non resistor plug use with EI - I have personally experienced non resistor plugs (NGK B8ES) “scramble” the brains of Pmags in flight.
What ignition system are you running with the L14-U?I have run other non resistor plugs, even with resistor caps, and got all sorts of noise on the intercom and immediately removed them. I know the l14u’s are listed as non resistor plugs, but I think they have resistors in them, though may not be the typical 5k ohms. One of these days i will put a meter on them. I have run them in my 320 with ei for 1000 hours and zero issues.
I have megasquirt setups for both of my planes. Inexpensive and reliable, though you need to fabricate parts to pick up crank position. On the 6 / 320, I also use one mag.What ignition system are you running with the L14-U?
