edward7048
Is anyone getting any audio warnings from skyview. Dynon said that I
should be getting some like autopilot disconnect.
Try it from the passenger side. If your's is like mine, and I'm betting that is, the Dynon voice will be much better from that side. I also have a problem with my intercom: ISO mode locks me out, not the passenger. It would be interesting to know if your's is the same.The Skyview audio alerts work for me but the volume is very low and makes it darned near impossible to hear the message when the engine is running and even less so when I'm in the air. I've gone into the system setup menu and my audio for all possible functions is turned on and the level is 100%.
Has anyone resolved this? I know what it should sound like because I did transition training in N412RV and the audio alerts while flying were easy to hear.
Bill, do you have the latest RV-12 schematic dated 07-08-13?are all the connections that pass through the AV5000 supposed to have continuity when the AV5000 is unpowered? Or must the circuitry in the AV5000 be powered for some of the signals to pass through?
My SV conversion harness package is operating the same way. No audible alerts over the engine noise with systems volume set to the highest. Also, the isolate knocks out me and not the passenger. The passenger knocks out the pilot. I'm sure it's a tko. I'll call Van's in the morning and hope there's a referee with the right answer.Try it from the passenger side. If your's is like mine, and I'm betting that is, the Dynon voice will be much better from that side. I also have a problem with my intercom: ISO mode locks me out, not the passenger. It would be interesting to know if your's is the same.
On the inboard side of the AV5000 are some audio output volume adjustments. There are two EFIS? adjustments marked L and R. I adjusted these (Can't remember which way to turn) and can now hear the skyview audio clearly.
That wont fix the intercom isolate problem. And weirdly, on mine some of the audio alerts are fine and loud (AOA beeping) and others are faint. I also intend to delve into the wiring on the intercom plug - figuring that will be the easiest place to solve the isolate issue rather than figuring out the av5000...
As a test, test it with your headset plugged into the passenger side. I get a significant difference. Haven't figured it all out though.
