Mornin’ guys. I’m at the point of attaching my tailcone to the fuselage and was curious how you guys decided to go ahead with this. The static lines are in as are the strings for the elevator and rudder cables (as per plans) The gas tank is in and the lines have been checked and the engine run (UL power). What else do In Ed to check/perform before mating the two?
Thanks in advance,
Thanks in advance,
