The instructions in section 23 call for a part named "ST4130-035 X 1/2 (powder coated)" for the aileron pushrods. But the closest thing I have in my kit is a pair of 1/2" uncoated steel tube in the photo attached. This is the last section in the wing kit, other than the wing tips, and I can't find anything else these would be used for, but when I look online at build logs, they definitely were using powder coated parts. Also, the wall thickness of these tubes is about twice what the called for part is. About .070 vs .035, so there's no way the threaded end piece will fit in there without significant machining. Did I get the wrong parts, or am I just missing the pushrod and these are for something else? If it's just the wrong part, any reason I couldn't use these with some machining? The original looks to be 4130 chromoly based on the part number, and I have no idea what these are. Also, the thicker wall means they'll be about twice as heavy, would that matter?
