pekuba1610
Member
Having finished the empennage, I finally drilled the elevator horn through the center bearing HS-309. The bolt head does not sit on the surface of the elevator horn. It touches the welding seam. Same thing on the other side with the nut.
Did anybody experience the same problem? How did you resolve it?
Thank you,
Peter
![](/proxy.php?image=http%3A%2F%2Fi288.photobucket.com%2Falbums%2Fll181%2Fpekuba1610%2FDSCN2408_zpsgxffc6va.jpg&hash=dd4cdc22f7cad82324e304d748714af6)
Thank you,
Peter
