Good rainy afternoon here in Georgia. Just curious if anyone had the STL file for the round split magneto wire holder that goes through the baffling on the back of an o-320?
Josh
Josh
Josh:Good rainy afternoon here in Georgia. Just curious if anyone had the STL file for the round split magneto wire holder that goes through the baffling on the back of an o-320?
Josh
Wow, the two hole version is $46?! That’s crazy!They have a 3 hole ad 2 hole at ACS the 3 hole is priced better.
search ignition wire baffle passthrough![]()
Search Results | Aircraft Spruce ®
Aircraft Spruce is the trusted source for aircraft parts, pilot supplies, and aviation equipment. Serving certified, experimental, and homebuilt aircraft worldwide.www.aircraftspruce.com
