The price point being bandied about by our engine reporter at KP is closer to $130K (but there is nothing official about it). From what I have seen, it is probably the likeliest contender to be successful in the small turbine department, but that’s a LOT of money to put on an RV-3 or (an underpowered @ 1410 HP) RV-4. The other thing to remember is that as soon as you have a turbine, you have to have an approved maintenance program for your aircraft, and you also have to have an “Experimental Aircraft Authorization (A Type Rating by another name) under current rules. So are required to comply with any Service Bulletins issued by the manufacturer. Right now, the entire Subsonex fleet in the US is grounded because the engine manufacturer has to replace all of our turbine wheels, and can only process four engines per month.
That piston engine is starting look pretty good…huh?
