bobrv7taildragger
Hassle vans to improve their quality control…improve the parts….replace the dodgy ones. Do you have under pressed parts?Ok, so what are you planning to do about it?
See above.There is never harm in asking questions; the issue is when you do not like the answer.
You are uncomfortable. So what will you do about it?
Implying that everyone else should also be uncomfortable changes nothing.
At the end of the day, you can either trust the designers or not.
If it still bothers you, you could always get a bead roller and modify the ribs to your specifications. You could also model the structure in readily available software to verify those specifications and compare that to a flat rib. That would tell you what you want to know…
A true Van’s fanboy reply, model the structure yourself, re-press all your bad parts… really?There is never harm in asking questions; the issue is when you do not like the answer.
I don't think it's a "fanboy" reply, it's a legitimate question. What are you going to do? Vans says the parts are fine, and meet the structural requirements of the aircraft without the beading. If they continue to take that stance, and I can't see why they wouldn't, what are builders going to do?A true Van’s fanboy reply, model the structure yourself, re-press all your bad parts… really?
When you pay as much as folks do for a kit these days it doesn’t seem unreasonable to expect a quality product does it?
Builders should not have to be Van’s quality control department.
Perhaps Van’s should reallocate some of the funds they spend on engineering validation of bad parts to a QA department.
Better yet would be to make sure every employee understands that they are the ‘QA’ department and they should take the time to ensure every part they produce must be of consistent quality, if not it should be tossed in the scrap pile.
Sure it is, because he's not in that situation.I don't think it's a "fanboy" reply, it's a legitimate question. What are you going to do? Vans says the parts are fine, and meet the structural requirements of the aircraft without the beading. If they continue to take that stance, and I can't see why they wouldn't, what are builders going to do?
so if you always get the ribs that you don’t like, then what are you going to do? Stop building? Even when Vans says the parts are good?Sure it is, because he's not in that situation.
What would I do... I'd be forced to purchase new parts and hope they have since corrected the problem.
If they looked the same as the 'bad' ones I'm replacing, I'd return them and try again later till I got good parts.
For me personally, I would probably pick up the metal fabrication process required to make them the way I want them. But that’s not reasonable for all builders.so if you always get the ribs that you don’t like, then what are you going to do? Stop building? Even when Vans says the parts are good?
That's the problem, folks have major investments in these planes so they can't afford to just walk away, they have to build, or face loosing significant $$.so if you always get the ribs that you don’t like, then what are you going to do? Stop building? Even when Vans says the parts are good?
But then how does the builder know if his homemade part meets the engineering standards from vans? And the airfoil shape, radius of curvature specs, etc? Not to mention there will not be any match holeFor me personally, I would probably pick up the metal fabrication process required to make them the way I want them. But that’s not reasonable for all builders.
Buzzword bingo! LOL!This was posted to Van’s website on 8/2/2024. May take some time and $$ to implement.
Van’s Aircraft Partners with Fuuz for Advanced Cloud MES and WMS Solutions - Van's Aircraft Total Performance RV Kit Planes
Van’s Aircraft has partnered with Fuuz, an advanced cloud-based manufacturing solution. This marks a significant step in Van’s manufacturing modernization process, enhancing operational efficiency and growth. Fuuz will enable Van’s to transition from a patchwork of technologies, including a...www.vansaircraft.com
And:
Using my engineering background and machining skills. That’s why it’s not a reasonable solution for everyone.But then how does the builder know if his homemade part meets the engineering standards from vans? And the airfoil shape, radius of curvature specs, etc? Not to mention there will not be any match hole
But my question is how do you do know your part meets the engineering specs, loads, stress, unless you recalculate them from scratch? What airfoil shape are you planning to use?Using my engineering background and machining skills. That’s why it’s not a reasonable solution for everyone.
This is all a thought experiment at this point as I have no skin in this current problem.But my question is how do you do know your part meets the engineering specs, loads, stress, unless you recalculate them from scratch? What airfoil shape are you planning to use?
I am not clear why people why people get their blood pressure up on this topic but based on what you said is perfectly acceptable for you, and the safety of the aircraft that is built based on your process.If you use the same material, same thickness, same fundamental process to make said part, you should arrive at a part that is as strong as built by Vans. I’d be happy with that result. Maybe that’s not enough for others.
Yes my question….are you affected by this issue?I am not clear why people why people get their blood pressure up on this topic but based on what you said is perfectly acceptable for you, and the safety of the aircraft that is built based on your process.
We don't know the "fundamental process" that Vans build their parts and we don't know the strength margin but some how we know the hack part is "as strong as built by Van's". A these hack parts are totally acceptable to build the replica Vans RVs. And , yet people are having a fit when Vans said the factory produced ribs are perfectly okay when building its Vans RV. There is something I am missing.
I am no clear why people why people get their pressure up on this topic but based on what you said is perfectly acceptable for you, and the safety of the aircraft that is built based on your process.
We don't know the "fundamental process" that Vans build their parts and we don't know the strength margin but some how we know the hack part is "as strong as built by Van's". An these hack parts are totally acceptable to build the replica Vans RVs. And , yet people are having a fit when Vans said the factory produced ribs are perfectly okay when building its Vans RV. There is something I am missing.
This is key. If the original part, as formed with the beads and such, was designed for a structure that is subject to 14.8 lgs/ft^2 *with a specific RDF*, say, 2.0, and no more (that is to say, it was engineered to meet the requirement and no more, which is fine), and the now-not-properly-formed part is analyzed and determined to meet some specific RDF, then we should know what that RDF is...is it the original 2.0? Or is it less than that, and if so, by how much?An RV-7 is designed for 14.8lbs/sqft. We don't know what safety factor was used, that's up to the engineer, who I believe was Richard VanGrunsven originally. The current engineer states that the under pressed stiffeners meet HIS margins. These less stiff components combined with other recent engineering misses (LCP and QB primer) have brought concerns with the current vans engineering group.
In the meantime, Van's continues to lose credibility by not owning the problem.
I'm simpler minded than the engineers on here. To me the stiffeners add strength in compression which contributes to the wing loading ability. An RV-7 is designed for 14.8lbs/sqft. We don't know what safety factor was used, that's up to the engineer, who I believe was Richard VanGrunsven originally. The current engineer states that the under pressed stiffeners meet HIS margins. These less stiff components combined with other recent engineering misses (LCP and QB primer) have brought concerns with the current vans engineering group.
As for how I would proceed; I'd squish a properly pressed rib in a press. Then either roll a deeper bead or rivet on an angle till it held the same pressure as a good one. Again simple minded.
Sorry Walt, it is NOT a "fanboy" reply; it is a legitimate question...and while there is little tone to this form of discussion, I don't appreciate the perceived condescension in your post.A true Van’s fanboy reply, model the structure yourself, re-press all your bad parts… really?
So again, I ask what are you going to do? If the engineers say that a perfectly flat rib will do the job and the bead is not required, are you going to stop building? Are you going to "roll your own"? Will you take the time to model the structure to get a satisfactory answer, which will likely agree with the engineer?
What will you do if Vans stops making the beaded rib in favor of a flat rib? Are you going to go hunting for the old style rib?
Did you blow a gasket when vans changed the ailerons on the -10 to make them like the -14? Why not? It is a changed structure and the engineers said it was ok...
The point is, things change. You can choose to believe the engineers, or not. If you choose not to believe them, where is the supporting data to disprove their statements?
"Feelings" don't apply. Either believe them or prove them wrong.
It would also seem that there are quite a few here that obviously know far more about Vans designs, business practices, manufacturing and fabrication of these kits. I read that Vans was hiring for several positions...might be a good fit and I'm sure they would appreciate the help.
"As for how I would proceed; I'd squish a properly pressed rib in a press. Then either roll a deeper bead or rivet on an angle till it held the same pressure as a good one. Again simple minded."Don't want to speak for Walt but since I was tagged I believe we both answered your question about what we were going to do.
Are these the same engineers that said build on with laser cut parts for over a year before finally admitting there was a problem?"As for how I would proceed; I'd squish a properly pressed rib in a press. Then either roll a deeper bead or rivet on an angle till it held the same pressure as a good one. Again simple minded."
You'd do this instead of believing an engineer?![]()
...and yet they produce successful safe designs. Go figure.Are these the same engineers that said build on with laser cut parts for over a year before finally admitting there was a problem?
And I believe I answered your question about what I would do if faced with this situation, I would not install a clearly under formed part.
Engineers are not gods, they work in a cubicle and most have never worked on the stuff they design, couldn’t shoot a rivet if their life depended on it.
There was a reason I chose Van's when I decided to build, it was because they chose to use proven/sound aircraft designs that I was thoroughly familiar and comfortable with. The further they stray from those design practices, the less likely I would be making the same choice....and yet they produce successful safe designs. Go figure.
So when they decide that a non beaded rib is sufficient and stop making beads ones, I guess you are out of luck?
