Was cleaning up a few things before I closed up the skins on the VS and completely cleated one of the rivets on the VS Top Rudder Hinge Bracket. It was a total struggle to try to drill this rivet out. In doing so, I must have gotten a bit off center because now the hole is a bit oblong. Any suggestions? Is there an oops rivet for an AN470AD4?
Any suggestions? Thanks for your help!
Perhaps I should take up bowling? Very frustrated right now.
Note that i do know that you're not supposed to drill all the way through. I had to try to go in from the back side with was a little bit cleaner but also cleated. The hole is oblong through the hinge, the spar, and the doubler.
