Angle valve sump & inlet
penguin
Patron
I have a straight forward question, can the Superior alternative sump & inlet be supplied with inlet tubes that will fit an angle valve motor?
Pete
I have a Superior cold air sump installed on a Lycoming IO390 (angle valve). The sump came originally installed on a Superior XP400.
If you are asking for superior cai sump for lycoming 4 cyl angle valve , try this p/n:
SV78950 KIT 2
Kit 1 is for O-360 parallel valve, kit 3 is for O-320
