Greetings,
I believe I've hit an issue with step 3 on this page where I'm instructed to insert the AN5-47A bolts. Namely, with the fuel tank installed, this is an impossible task to perform as illustrated
Has anyone else hit this? I will call the mothership on Monday to see if it's acceptable to insert the bolts from the other direction or to find out if I'll need to remove the tank to insert these correctly.
Any advice appreciated.
