Yes, they do that
I spoke with Bill about this. The plastic housing for the spade connectors on the back of the alternators can lead you to believe they are making good contact just from the friction force of the connector assembly itself. It helps to use needle nose pliers and give the spade connectors a little squeeze to tighten them and then put some dialectric grease on them to prevent corrosion.
Vic
Vic
