Electrical problems are so much fun...
On the last few flights my 60 amp Plane Power Alternator has dropped offline, then a while later in flight come back on. I did an oil change last week and checked all the FWF connections and everything seemed tight and secure.
While flying yesterday it quit again, about 5 minutes from home base. Now here is the weird part...when I engaged the flap switch (standard Van's setup) in the downwind for landing the alternator came back on and stayed on. I have attached the Savvy Analysis image showing volts/amps and flap position/fuel pressure (yes I forgot to shut off the fuel pump until mid-flight, thus the higher amps for a while). Ignore the first 10-min., that was unrelated Skyview ground time.
My setup is a PP 60 amp alternator, pullable field CB, split master switch and Dynon Skyview. I have an idiot light from the PP alternator and stand alone voltmeter/clock, so I know it isn't just a bad Skyview indication. Only about 100-hours on the engine/alternator.
Since I didn't see a problem FWF, my next step if more behind the panel checks for security. Any other suggestions would be welcome.
