Alert: Tail Section 09-20, Part E-15008-001
Louise Hose
Sponsor
UPDATED IN RED: I am finishing up my left elevator and have been jerked to a sudden stop by what appears to be an incorrectly punched row of holes. The outboard-most row of holes seem to be mis-aligned with the tail skin (and, likely, future fiberglass tip). I was able to Cleco the length of the two interior rows but the outboard row does not line up with the skin holes below. In addition, the aft-most hole on the outboard-most line doesn't have proper edge distance. After a consultation with Van's, this hole should be 1/4" from outer edge of the hole to the end of the strip on both sides. Mine are1/8". They will be sending me two replacement pieces.
I have talked with Van's and they are looking into the problem. I have no idea if just my set of pieces are affected or it is a more general problem. (I suspect the latter.) But, if you are building the elevators, check this piece and its fit to the skin before working with it. For me, I'm stopping work at Elevator Assembly Page 09-20 until this issue is resolved. No problem, as I have plenty of work to yet do on the other elevator and the horizontal stab. I was able to pick up at page 09-22 and complete the elevators except this elevator counterbalance skin.
If you haven't followed my vertical stab and rudder posts, the tail is coming together incredibly fast and easy! The kit has been a joy to work with this being the first (and only) issue with parts (or KAIs). If one is on the cutting edge, you have to expect a few surprises.
The circled hole at the end of the problematic line doesn't have appropriate edge distance, a hint the the line isn't properly placed. After a consultation with Van's, this hole should be 1/4" from outer edge of the hole to the end of the strip on both sides. Mine is 1/8". They will be sending me two replacement pieces.
The two inboard (lower) lines of holes line up perfectly with the holes in the elevator skin and two ribs below (although I hadn't put the outer rib in place during this photo). The outboard (upper) line of holes does NOT line up with the holes in the underlying skin.
Thanks, Louise! I just checked mine (haven’t started the elevators yet) and the end hole / edge distance is the same.
I’m just glad this is a small piece and not the entire elevator skin, much easier to ship replacements if that is needed.
I just received an email from Van's that I expect all of us first 20 tail kit builders will or have gotten. Titled "RV-15 Important tail Kit Notice: Section 9" It acknowledges the mistake and says:
"As you’re building, please stop before you begin Step 09-20 in Section 9 of the RV-15 Kit Assembly Instructions (KAI).
Replacement skins are being produced as of 5/21/26 and will be shipped as soon as possible at no cost to you. Two skins will be sent, as the error affects both left and right sections.
Thank you for your understanding.
Van's Aircraft"
I found that I needed to skip pages 20 and 21 but, otherwise, was able to complete both elevators. Adding the strips will be super easy once they arrive.
By the way, this can not be fixed properly with a template like the rudder error. Drilling the correct holes will result in figure 8s.
