dbuds2
Has anyone ever experienced the idle stop screw rotating to increase the minimum idle RPM during a flight? This is the screw with spring tension that sets the arm closed limit. During a landing it seemed like landing with a tail wind as I kind kept flying down the runway. When I braked and turned off, I noticed I could not get the idle lower that about 1100 rpm, usually I idle at 600 rpm.
I don't know if this is the cause or not yet. At first glance, the arm is still bottoming out on the screw .
