I'm using the James MK234 filter assembly. When I line up the front hole perfectly with the cowl the rear hole going into the fuel injector is a bit off. It covers up some of the hole on the injector. What should the remedy be? Is it Ok to have a small portion of that hole covered or will the engine not run perfectly? I can do some fiberglass work to adjust the hole in the transit duct so there is not any part of the hole covered. Thoughts??
![20220306-112328.jpg](/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2Fq7k9nD9K%2F20220306-112328.jpg&hash=d41ff35a57d088b535a7fd7c5fcf7a6c)
![20220306-112303.jpg](/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2FjdxgQyMR%2F20220306-112303.jpg&hash=6b255527c497e6e1125a3ec1499ecf8e)
![20220306-112357.jpg](/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2F13TvQ2sz%2F20220306-112357.jpg&hash=85928f67e8f4db54a176f9d6651f605b)
