I have an electric trim question for the RV14. When right stick is applied, the right wing pushrod moves inboard, the aileron pushrod moves fwd, and the right aileron deflects upward for a right roll.
Assuming the trim is centered, this puts more tension in the outboard spring than the inboard.
Now let me have a heavy left wing so I’m applying right force to stay level. There is more tension in the outboard spring. If I want to transfer my pressure to the trim mechanism I would move the actuator outboard and let the inboard spring have more force. More force on the inboard spring means less stick force is needed.
On the ground if I have no other forces and move the actuator outboard for right trim with a centered stick the pushrod will have a force that will want to pull the pushrod inboard. When I release the stick it will tend to go right as the force is released from the actuator spring to move the stick right and the right aileron up.
Is all that reasoned correctly? Big picture is right trim is putting in right stick. And if I center the stick I should feel a right force on the stick.
