In doing a final pre-flight inspection prior to a first flight in the coming weeks, I found that one of the stops on my ailersons had cracked off. The original builder welded a small tang on each bracket to act as the "stop", and one is there but the other has "departed the fix".
Anyway, my copy of the plans isn't very good, and the fine print shows what looks like a flat piece of 3/16th inch T-2024 riveted to the bracket with 426-AD4-10 rivets.
Is that what you all have on yours as well? I seem to remember making the stops for my RV-9A ailerons with a small piece of angle alumimum...
Thx.
Doug Lomheim
RV-3A Restoration
https://www.dropbox.com/s/vdq2frcam7j22n5/Aileron stop broken.jpg
Thx.
Doug Lomheim
RV-3A Restoration
