In my projects a few things have really caused me a headache. Like the trim tabs. Like the big rivets in the aileron push tubes. Yes I could weld them. I didn’t. Finally figured out how to set those rivets cleanly after many fails. Like a video game where you die and die and finally the boss goes down!
But I was amazed at how hard it was to bolt the aileron pushrod to the aileron with it mounted on its wing attach points already. Struggled massively, then decided to unbolt the aileron, attach the pushrod off the plane and then return the aileron to the wing with the pushrod on.
This worked great. I’m sure I’m not the first to fight this and problem solved. I wonder if anyone has a neat trick for attaching that pushrod with the aileron mounted. I could not do it.
