question. . .
how much lateral play should be in the ailerons? or more specifically, what is the best way to build up the hardware stack for the aileron attach brackets? the drawings show the hardware pretty well, but then it says something like "spacer- - as required" or words to that effect. also, it seems the aileron position is influenced by the stack up of hardware and spacers, which will then influence the location of the flap.
