Draker
Looks like back when I was drilling my wing ribs to 7/16" for the cable runs, I got carried away and drilled all of them, including the outboard-most rib, which the manual says to not do before aligning the ailerons. Any chance I can use the tooling hole on the leading edge (B) to align the aileron instead of the one on the main wing rib (A)? Eyeballing it with a straight edge, it looks like both holes are on the same line to the tooling hole on the aft end of the main rib.
If not, I wonder if I can get away with using a 7/16" dowel on the aileron alignment thinggy rather than a AN3 bolt.
![IMG_0691_M-M.jpg](/proxy.php?image=https%3A%2F%2Fphotos.smugmug.com%2FRV7%2FWings%2Fi-xsbRkxT%2F0%2F33e74a07%2FM%2FIMG_0691_M-M.jpg&hash=3f2911607c2bf70b007fd8b8e38c5e5b)
