WingnutWick
So I had just had a nice long run with nothing going wrong with the planes and I made the mistake to have the sabatoging thought “wow, it’s been quite some time since anything has gone wrong with the planes!” and that’s when I knew I messed up. Sure enough next flight P-Mag failed its internal power check on the 10 and just yesterday while airing up a tire on the 8 I see blue streaks of fuel seepage on the bottom of the wing spanning the length of the tank seam. I peeked around and couldn’t see any leakage from fuel tubing, and bore scoping behind the tank showed blue fuel witness marks and a little dark spots of un-evaporated fuel lining the back of the tank (as expected from the seepage in this photo).
So, first off - how much of a pain of a fix is this? Secondly - what are the steps to fix this? I need to assess if this is a me project or a throw money at the problem project.
Thanks all!
WN
Thanks all!
WN
