Aeroquip hose question
bob888
Sponsor
The hose from the fuel servo to the flow divider on my engine is over 10 years old. It has a tag showing Aeroquip HAE 4Q02 (a bunchof other codes are on it as well). Does that code mean anything to the VAFers out there. I doubt if it is a lifetime hose and I suspect it is overdue for replacement.
Bob---check to hose to see if its 303 or 666. It might be teflon and be non life limited----but check it anyway. The numbers on the tag will be the part number, the pressure test data, the data of manufacture ( you already know that) and sometimes the shop code.
Tom
