Here are some photos posted on VAF:
Here is info on the mounting hardware:
Just for some further info on the mount Kelley made for the sun ray... (the one Dean is refering to). The compression springs can be obtained through Vans & normally come in the RV-10 landing light kit. They are in harware bag 635 of that kit. The contents of that hardware bag are below (I've highlighted the spring part number). I hope this helps anyone else looking to mount SunBeam or alike light in the tip. Like I mentioned, for the square frame SunBeams I'm using a 3 piont swash plate (adjustable mount) set on these compression springs. When I'm done, I'll try to remember to post pictures here and share all the other info with Dean.
BAG 635 RV-10 LL HARDWARE
0.010 AN426AD3-3.5 RIVETS (LB)
0.010 AN426AD3-4 RIVETS (LB)
1.000 AT6-058X5/16X4 ALUM TUBE {INCHES}
14.000 K1000-06 PLATENUT 6-32
4.000 MS21051-L06 632 SINGLE LEG P/NUT
6.000 MS51957-36 SCREW 632X1 1/8 PAN
2.000 SPRING .26X2.9 COM COMP SP FOR LL KIT
12.000 AN515-6R8 SCREW,ROUND HD
2.000 VA-194B MR16 RETAINER PLATE
2.000 VA-194C MR16 CUP
