I'm considering an Aero Momentum engine for my -12 build. Looking for other builders and their experiences with this combination. My email is [email protected]. Thanks for any help.
From my own experience, I wouldn't do it.I'm considering an Aero Momentum engine for my -12 build. Looking for other builders and their experiences with this combination. My email is [email protected]. Thanks for any help.
Yep I have worked with Dick on the Fuel Lines of an RV-12iS airframe and not the RV-12 airframe. He was very interested in the connection that Van's AircraftDick Gossen built an RV-12 with an aero momentum engine and spent quite a lot of time and money trying to make it work, but ended up with a few off-field and precautionary landings, and then ultimately switched to a UL. I built my -12 with a UL350iS and found it was an excellent engine, but it took a lot of extra time and effort FWF to get the setup completed, mostly involving the cowl and oil cooling. But once setup, it was a very smooth, torquey, screamer.
If you really want to pursue the AM engine, I'd highly recommend connecting with Dick.
I enjoyed the process, but unless you really just want to put the 'E' in Experiment, you might save a lot of frustration, spend the extra money and go with the factory setup.
I work with Dick with the latest RV-12 Aero Momentum kit 2024. Dick was very interested in the RV-12iS (2) fuel lines and how they were connectedDick Gossen built an RV-12 with an aero momentum engine and spent quite a lot of time and money trying to make it work, but ended up with a few off-field and precautionary landings, and then ultimately switched to a UL. I built my -12 with a UL350iS and found it was an excellent engine, but it took a lot of extra time and effort FWF to get the setup completed, mostly involving the cowl and oil cooling. But once setup, it was a very smooth, torquey, screamer.
I work with Dick with the latest RV-12 Aero Momentum kit 2024. Dick was very interested in the RV-12iS (2) fuel lines and how they were connected thru a Bypass fitting. There was a Venture hole between the two lines. Van's Aircraft Genus! Disk had no experience with RV-12iS builds!Dick Gossen built an RV-12 with an aero momentum engine and spent quite a lot of time and money trying to make it work, but ended up with a few off-field and precautionary landings, and then ultimately switched to a UL. I built my -12 with a UL350iS and found it was an excellent engine, but it took a lot of extra time and effort FWF to get the setup completed, mostly involving the cowl and oil cooling. But once setup, it was a very smooth, torquey, screamer.
Howdy there;I'm considering an Aero Momentum engine for my -12 build. Looking for other builders and their experiences with this combination. My email is [email protected]. Thanks for any help.
Continuing Ground testing on my RV-12iS and the Aero Momentum Engine. Coolant max at 218 and Oil Temp at 240. Need Oil Cooler!Doing Ground testing on my RV-12iS and the Aero Momentum engine, Finally got the Luga propeller blade angles within range of 10 degrees.
It's a powerful engine with normal RPM range 1800 to 5800 rpm.
Found a Aero Momentum invoice date Apr 18 2023 for oil cooler and Mounting kit and wired them $429.00 from my bank.Continuing Ground testing on my RV-12iS and the Aero Momentum Engine. Coolant max at 218 and Oil Temp at 240. Need Oil Cooler!
Aero Momentum refuses to sell me there Oil Cooler Kit for there engine because of a 300.00 business dispute!
Adjusted Blade pitch to 23.5 and tested. Aircraft moves better on ground but airframe vibrates very badly with Aero Momentum Engine!Continuing Ground testing on my RV-12iS and the Aero Momentum Engine. Coolant max at 218 and Oil Temp at 240. Need Oil Cooler!
Wired funds from my Bank to Aero Momentum Bank routing/account fail twice? Contacted them about it and was ignored...Found a Aero Momentum invoice date Apr 18 2023 for oil cooler and Mounting kit and wired them $429.00 from my bank.
Send copes to All known Aero Momentum emails asking them about shipping and tracking numbers of kits purchased.
Contacted Aero Momentum about loud vibration Ignored; no solution?Adjusted Blade pitch to 23.5 and tested. Aircraft moves better on ground but airframe vibrates very badly with Aero Momentum Engine!
temperatures still high.
Made written request to purchase Aero Momentum Oil Cooler and Mounting Kit. Very, very risky to test fly N5415J without Aero Momentum Oil Cooler toContacted Aero Momentum about loud vibration Ignored; no solution?
Aero Momentum continues to ignore my Phone, email and texts requests to purchasing there oil Cooler and Mounting Kit for there
aero Momentum Engine.
From Aero Momentum installation Manual:
OIL COOLER (optional) Depending on your installation, application and version, you may need an oil cooler and one is recommended for most installations. We offer an optional oil cooler kit. But Not to Me? RV-12iS Grin
Hi there; I build and installed an Aero Momentum engine in my RV-12iS. CG was out of limits and needed to revise weight & balance with 20 lbs BallastI'm considering an Aero Momentum engine for my -12 build. Looking for other builders and their experiences with this combination. My email is [email protected]. Thanks for any help.
