Hi all,
After some more advice on the next stage of my project. Have an A1B6 that’s been bulk stripped for IRAN and I need to convert to 12V set up. I will order a Hartzell constant speed prop (C2YR-1BFP/F7497-2 ,72 in. dia) from Vans but the ignition set up may influence that - not sure? So my queries:
1. Alternator. I have a PP/Hartzell AL12-E60/B that came with the FF kit but I believe having read another post this may not be the best one to use which is frustrating becomes it becomes a large and expensive paper weight. A friend of mine also had one that failed inflight. His suggestion is a B&C with external voltage regulator. Thoughts?
2. Starter Motor? Any recommendations appreciated.
3. Ignition system. Existing magentos will need to be switched out I assume being currently a 24V system. Interested in electronic ignition but there’s pro and cons and I’d prefer not to run a second battery as backup. Interested to learn some opinions or experiences with this.
4, anything else I haven’t considered?
Once again thanks in advance.
