I posted a few weeks ago about my incidence challenges. I have since pulled both lower rear wing spars and am ready to put the new ones in. I used a poor method to remove the rivets and bent the inner flange on the interior ribs, making it difficult or impossible to get a solid rivet back in there. My plan was to use cherrymax rivets there and use pressure from behind to hold the flange in in place while my son pulls on the cherrymax. Vans did not seem to have a problem with this approach as it is only a few rivets. I could also just drive the new rivet skipping the web flange and only hitting the rear support, as for all the other rivets, but preferred to have contact there. Vans didn't have any real issue with this either.
I got to thinking how will I know if I am getting shop heads close to correct on all of the other spar rivets. I certainly cannot feel them and I am not sure I can get both a mirror and a flashlight in there. I will be using a long steel rod as a bucking bar. The question is, which is the better risk, cherrymax rivets for all of these or possible risk of poor shop heads? I did a bunch of research before feeling that a few Cherrymax would be ok and it seems they are pretty close in strength, without the vibration problems associate with pop rivets. However, it is a critical part.
Thanks for your guidance.
