Ailerons
In most cases a disconnected aileron will trail in the neutral position. Some of the Reno biplane racers have disconnected the upper ailerons on four aileron Pitts and removed the "slave strut" that connects the lower aileron to the upper to reduce drag. The upper ailerons appear to be held in neutral with tape.
Most any airplane will fly just fine with one aileron disconnected. How much adverse yaw is involved will depend on how much differential the aileron system has and how aggressive you are on the controls. It would be best to make all turns in the direction of the "good " aileron and make all control movements slow and smooth.
Kent Pietsch used to jettison one aileron from his Interstate Cadet during his comedy airshow routine. I haven't seen him fly for a few years.
The elevators on some airliners are not connected directly to the control system. The control system is connected to "control tabs" which move the control surface. On the DC9/MD80 series if the airplane is parked with a tailwind you may see one elevator full up and the other full down. They do have hydraulic dampners to keep the controls from banging against the stops. The DC9/MD80 also has hydraulic control for down elevator only, but this is not "full time" and really is just there for "deep stalls" with the T tail.
