az_gila
A question for those who have mounted a 9 row cooler on the aft #4 baffle of a RV-6.
How much clearance did you end up with at the aft inner cooler flange and the motor mount?
If seems if I move the cooler all the way out board - no 1/4 inch offset as shown in the new baffle plans - I can only get 1/4 inch sideways clearance after trimming the cooler flange to essentially zero.
Other builders have mentioned they did it, but how much clearance did they end up with ?
Vans says 1/2 inch, but is 1/4 workable?
The engine is a narrow deck O-360-A1A and I have the new baffle kit.
PS question is specifically for -6 installations, photos seem to show the -7 and -9 mounts are slightly different.
