BillL
I hear the Hartzell blended airfoil is good for 6 g's. OK -Fine, well what is the composite good for with a 2.5" spacer? For gyroscopic bending moment in a loop or pull out, the equation is moment=inertia*angular velocity (prop)*angular velocity(of planes path). OK, yes we need the off set from the base of the prop flange, and the equation modification for a two blade prop. But, I calculated the rad/sec for differing G loading upon entry of a loop (for instance). If the calcs are correct, then it seems the plane speed is a big factor for 6 G capability. The same bending moment on the crank is at 4 G's, 140 mph, or at 6 G's at 210 MPH. So the big question - at what speed is this calculated? 6G's at maneuvering speed?
I will measure the Moment of inertia via the bifilar pendulum method, but that just gets me in deeper in the unknown. Can anyone help with the conditions under which the official G limit (for the prop and engine flange) is determined? and who does it, Lycoming, or Hartzell, or the airframe designer?
Enlightenment would be greatly appreciated. Thanks!
