????? thinking of converting a 6A to a 6???? looking for advise.
1. ? Anyone recently done this?
2.? Does Van's sell a conversion Kit with instructions?????
3.? Looks like it pretty straight forward on front of aircraft, replace motor
mount & legs, remove bulkhead for 6A ??.
4? Must you remove the vertical stab & horz to beef up the tail for tailweel?
5? Can you just peel back the side skin on both sides to replace the kit????
from the sides????
Or must you drill out the top plate also to install the kit? from the top (if there is a kit)????
Thanks for any advise.
from the sides????
