This is a nose leg from a 6A, off the airplane for a SB 07-11-08 fork upgrade. The original builder glassed on what appears to be a hardwood stiffener.
From the color, it appears to be polyester resin and glass, which makes sense given the vintage. It wasn't strong enough to stand up long term, so the glass fiber appears broken.
It's hard to know what the builder had in mind, cosmetics or reinforcement, but it seems to me the application requires treating it as a reinforcement, or it will just crack again, as above.
The trick box here is the difficulty of knowing the applied load at the joint, in order to know how many plies of what material needs to be in the new layup. Best approach is probably empirical. Anyone have application experience with a nose leg stiffener like this?
