tomkk
It looks like Figure 2 shows the sensor held tightly against the F-00036 bracket & grommet. When I install the elbow from the bottom, it actually protrudes slightly above the grommet and the base of the sensor (the bottom of the hex "nut") is well above the grommet. The result is the sensor is sitting above the grommet held only by the friction of the grommet against the outer surface of the female part of the elbow. Can that be right or have I missed something?
